  #32
Old 27th January 2016, 02:58 PM
Thanks for that Ainars. I was/am a bit sceptical as it still relies on picking up the signal INSIDE the car which seems to be the issue with the metallised coating on the heated front screen. But I then noted in the product reviews that someone states that in their car with a "metal oxide coated screen" which previously inhibited signal reception, this device solved the issue. Not cheap at nearly £40 but worth investigating.
EDit: Just seen that although some people mounted the receiver aerial inside on the dash others did mount it as I now think it should be receiver aerial on the outside of the car.
