Old 2nd June 2016, 01:56 PM
Originally Posted by muj33b View Post
Hi sorry If I may sound a bit naive but my 2003 a8 does not have the TV installed would I still have the red connector and harness to plug into the analogue tuner box if I was to purchase this and then install the fusion bt-100??
P.s. It's a 4.2 v8 petrol not sure if this makes a difference but just incase.
Hi and welcome.
I believe the wiring loom was bespoke to the car, so if it was spec'd without the TV you won't have the wiring installed.
Matt
Old 2nd June 2016, 03:00 PM
muj33b muj33b is offline
Thanks for the reply I was hoping that wasn't the answer I would receive but I guess it is what it is. Thanks again for the quick reply.
Old 2nd June 2016, 03:02 PM
AMI would be the route I would go down and have all your MP3's on an Ipod or USB flash.
Matt
Old 2nd June 2016, 06:36 PM
This may seem a bit sad but I would also like to have bluetooth to stream music and also as a handsfree
Old 3rd June 2016, 07:37 AM
mmarksx19 mmarksx19 is offline
Can I ask where the RCA cables are sourced (in the UK)? I would be interested in doing this until I can afford a full AMI install.
Michael
Old 3rd June 2016, 07:52 AM
The RCA cables must be installed if they havent been already, they are attached to the large red connector that goes in to the TV Tuner in the boot
Old 3rd June 2016, 09:16 AM
Sorry, I wasn't very clear. Where in the UK can I buy the RCA cables to plug into the red connector? The fusions unit can be purchased on ebay or amazon but I want to ensure I buy the correct cables so they fit the connector without being too loose or too tight.
Michael
Old 3rd June 2016, 09:40 AM
Michael
I bought mine from ebay
http://www.ebay.co.uk/itm/400779555363?
Matt
Old 3rd June 2016, 11:33 AM
That's perfect. I assume the description in ebay is incorrect.
'Please note: This item is NOT compatible with stereos that have the 6 CD Player built into the stereo.
This auxiliary input adapter enables a seamless connection of external audio source to your factory fitted radio. You can connect any audio sources ( such as portable MP3 player, iPod, etc ) via RCA sockets or by using the RCA to 3.5mm headphone cable.
This auxiliary input interface connect to original head units via the CD changer port and trick the unit into believing it is playing a CD changer, whilst really playing the audio from another sources. This means the audio can be produced at a much higher quality.'
Old 5th June 2016, 08:54 AM
Cables and Bluetooth receiver ordered. I'll let you know how I get on.
Michael
