Old 15th June 2016, 08:26 AM
Ideally you want to run basic settings from the climate module with vcds to exercise the motors. If there's a problem it will then flag it with a fault code
I changed mine recently and it's on the passenger side of the air box, with a rubber pipe right in the way of 2 screws that need to come out to remove the cover over the flap motor. The cover also has a rubber gromet that needs to be carefully re-seated when you put it all back. With the cover off its 2 screws and a plug to remove the motor. Mine looked fine inside when I stripped it down and worked of a fashion, but was clearly tired
Bad news is that new motors aren't cheap - over £100 - but are available. I posted about my experience on here recently. You need to run basic settings again after fitting a new motor so it learns it's travel
