Old 23rd October 2016, 03:44 PM
As MJ says its a press fit joint and perhaps may go back together after a clean. However, it does look pretty worn and may well be beyond repair. The only problem with a second hand unit is that the linkages may well be worn too and it will be a "slapper" at best. I exchanged a unit with The Laird and so at least one of his (the one with the good motor) will be worn - I am sure he wont mind me saying this . The one I got from him has been OK but is now over-running on full speed. I have thought about ways to adjust the the linkages as the motor is OK and I am sure that the unit comes with motor/arms etc.
Sounds like MJ has a business opportunity upgrading wiper arm units!
Old 23rd October 2016, 06:04 PM
YorkshireBloke's Avatar
Unhappy Better to KNOW even bad news...
Hi,
Thanks for the tips, I didn't even know it was a ball joint... that is how coroded the thing is!
If anyone knows human anatomy, the hip "ball" has a neck, that is what old people break, the neck of the femur (oh, and I'm not a Doctor as well as not being an engineer!).
The linkage had broken the neck of the femur, you can't see a ball at all... It must be in the plastic bushing". Will look of course.
OK. On planet earth there are lots of ball-joints so has anyone ever tried to re-purpose one for this linkage? If I find a source I'll pass it on!
But for now I will remove the whole assembly and check for wear elsewhere.
Also I'll do some research into Construction and Use regs. It may be an offence to drive without wipers... But on motorcycles if all wiring and fixings are removed for say, indicators, then that is OK, whereas a broken bulb is braking the law!!
Robert
Old 23rd October 2016, 10:17 PM
Wow I see it now on a closer look! I hadn't even realised the ball had gone. Thats slightly harder to fix...
Old 25th October 2016, 07:51 PM
Thumbs up Ball and socket joints
Hi,
A quick search of ball and socket joints online shows lots of options,
http://www.automotioncomponents.co.u...t-joints/r3520
Early days yet but if I can't find a mechanism I think the removal of the old ball and socket joint (s?) and replacement will be possible.
Anyone want to share a batch of 50??
Robert
Old 26th October 2016, 05:46 AM
Ameiseuk's Avatar
Ameiseuk Ameiseuk is offline
As with most manufacturers the common bits are mass produced by outside contractors. Audi arent going to have just a couple of thousand ball/socket combos produced just for a d2.
If the linkages are ok, the engineer in me would try and source the linkage off another vag group car of similar 'size' ... vw phaeton, wv passat or audi a6 spring to mind.
There are bound to be nos ones floating about on ebay or similar.
Use the ball/socket off these and repair your own. The bits are normally clipped in or worst case a circlip to hold them under the gunk.
Daily drive:
Current 'Project':
Previous 'Projects':
2000 Audi S8 FL
www.whall.co.uk
Old 26th October 2016, 06:34 AM
I've got a couple of D2 wiper mechanisms, one more worn than the other. The plabn is to replace the ball joints (3 I think) and refit one to my car, then do the same to the mechanism that I take out.
That would leave me with 2 refurbished mechanisms - at least one of which I'd sell on.
I think David might be up for the same job, so that's 12 of your 50 joints accounted for!
Do you have a local engineering shop that would do it, or was that a joke?
Old 27th October 2016, 07:29 PM
Default Engineering Shop
Hi,
My engineering shop is called Nick. I am swapping ridiculous tales and making outrageous plans with him tomorrow night (i.e. Going to the Pub).
Out of my regulator drinking pals he is the only one who MAKES anything; the rest of us move goods from place to place (shopkeepers ), office-walahs (civil servants ) and a psychiatric nurse (handy!).
Will report back! Soon, or.have to SORN A8 till fixed
Robert
Old 2nd December 2016, 07:23 AM
Simple question: is the new genuine Audi replacement mechanism still available from Audi/TPS? If yes, I'd thank god, order the damn thing, replace and that will give me another dozen of happy years.
I'm thinking to change mine preventively and save old one in case it'll appear to be repairable in the future.
Tags
wiper failure
