If you can't get the connectors, to save cutting wires you could make up a couple of connector 'bypass' leads using 'bed of nails' test clips to determine if the problem is at the connector or the motor.
http://www.ebay.co.uk/itm/1pair-Angl...-/281896808055 http://uk.rs-online.com/web/p/products/7148281/
Thanks, I have quite a few ideas on how to bypass the connector, but those look handy.
![]() I do want to avoid cutting wires if at all possible as they are already pretty short.
It might as well be blower motor gone. Quite common in cars with solar sunroof as it's working overtime. When mine went it would sometimes work , sometimes not and if you hit near it or went over pothole it would start working again. Eventually it got slower and more non working than working. I was hoping it's just the brushes worn but turned out that while brushes were low it was mostly due to slip ring/commutator wear so I got replacement from A8parts. I did ask them for one from a car without solar sunroof and the one I received was very good condition with minimal wear.
If it is, how easy is it to replace?
I actually fitted a cutoff switch on the solar panel circuit to stop the constant tickover of the fan unless I wanted it on, though it had many years before my ownership.
I've just done one. Not easy at all, although I had the engine out which helped considerably!
![]() 2 challenges: 1, two of the screws for the blower cover are underneath the rear section of the airbox under the windscreen cowl. You can't remove this section with the blower in place, but you can't get directly to the blower screws with this section in place. I have a tiny ratchet which takes screwdriver bits which allows me to get to these two screws from the side instead. If you don't have such a thing then a flexible screwdriver might work. Failing that, remove the wiper mechanism and then you can detach the rear section and it will move about just enough to get a long straight screwdriver in, assuming the screws are in good condition. To remove that section with the blower in place you need to either remove the brake servo or the electronics box and aircon pipes. Utter madness. 2, in every D2 I've worked on 95% of the screws in the airbox are rusty stumps due to it sucking in our nice damp atmosphere. It takes a lot of patience to dig out the phillips-slots in the screw heads and then still many of the heads snap off when you finally get a grip on them with a screwdriver. A good pair of mole grips works for some of them, but access is difficult to most. A brand new blower is just shy of £300, but remarkably in UK stock so available next day. I always keep a dozen of the little screws on hand so I can replace whatever does come out with new. |
If it does turn out to be that I might ask you very nicely and have a trip down to Devon.......
I can attest to the aircon airbox screws being completely rusted. Already snapped head off one. And this is on a car that lived in Germany. Why didn't they use stainless or anodised screws the cheapskates?
You may want to try mixing up a solution of acetone and vegetable oil (from the supermarket). Around 50/50. It makes for a very good penetrating oil. Leave it soaked for a few hours then it may reduce the chance of those screws snapping. |
![]() And they do seem to have a special tool, similar to what you describe, to get at the awkwardly-located ones. ![]() I guess with the engine out you can get right up to it quite easily. I'd be interested to hear how Ainars got on when he did it. ![]()
As an aside, I also notice that the black foam around the outside (that seals against the bonnet) is falling apart, I even got bits of it blown into car during testing.
![]() Is this a "thing" that's worth buying (if available) or would any decent foam of suitable thickness do?
