Old 6th February 2018, 07:48 AM
Originally Posted by B4-Andy View Post
Finally found someone with a clean shell and an angle grinder! Sorted thanks
I want to see it welded
Make sure you have an aluminium cutting disc in the grinder as aluminium can block the discs for steel, they get hot and can explode.
Old 14th February 2018, 10:27 AM
B4-Andy B4-Andy is offline
Ah no chance, I'm not doing the work, it'll be off to a body shop to get that work done! I want it done right, the last bodywork I did ended up a disaster, think Father Ted when he tried to hammer a ding out a Montego...
Old 14th February 2018, 10:32 AM
Oh yea, the other really interesting thing on the back of the rear quarter is the prolific use of expanding foam!? In behind the panel there's plenty of it, found that a bit odd!
Old 17th February 2018, 08:56 PM
Audi use it in quite a few places. The a-pillars on B5 and C5 are full of it, as are the sills on those and the D2. Its useful for stiffening and sound absorption.
Its not fire-retardant either. I found that out when I tested a sample before having the sill welded on Dean's Big Red - it burns quite well. Ended up digging it all out and then re-applying it once the weld was finished.
Old 19th February 2018, 08:16 AM
S5 Sportback roof rails are also full of it - used a lot now for structural integrity in safety critical areas to help maintain structural stiffness of the panel
Old 21st March 2018, 09:04 PM
Well my darling partner reduced the panel to tin-foil. She has since forefit all rights to complain about my driving, which almost makes it worth it. Almost.
Old 24th March 2018, 08:25 PM
How? What happened?
