Old 3rd January 2019, 06:43 PM
Interesting - the Aldi one looks a bit like an Anycubic i3 derivative. I can build my own for that though
The only models which may be of use to you are the Y-motor brace which is on Thingiverse, and the 40mm cooling fan which still needs work. I'll post that on Thingiverse when its done though. Its a remix of one that's already on there.
Pretty much everything else is related to getting rid of the control box so not a lot of use to anyone else. I actually binned quite a few of the other mods like the rubber mountings for the steppers as although the reduced the noise, they also reduced print quality. I've taken the frame braces off too since one of them broke. It doesn't appear to have made a significant difference tbh since most of what I print is <100mm tall.
Once the base is finished and the aforementioned dual extruder added I''ll build a new machine. I have an Anet AM8 in the works, and a Hypercube following that
