#30
As Dezzy says. Screw driver to take of the air box to throttle body pipe (2 jubilee clips). Allen key to remove the cover. 10mm spanner to take out no 4 coil and swap it with number 3. Replace air pipe and clear faults with vagcom, go for a drive and see if it moves to three. Do the same for 1. If it don't move, do the same with the plugs and see if it moves.
Which water temp sensor? You have 2. One in the head and one in the radiator I think.
