Old 10th August 2019, 08:31 AM
Originally Posted by Timon View Post
Was trying to clean and dry, but fitted after 1hour dry.. Maybe just thats why its doesnt work for me
Maybe You can give advice what kind of cleaner to use on it ?
If you remove the internals you will find a PCB and a bunch of plastic parts. In my case the previous owner seemed to have spilt coke on the controls, so the plastic was sticky, I just soaked all the plastic parts in soapy water, washed by hand, rinsed with clean water and then finally rinsed with IPA to speed the drying time.
That said, if the PCB is also contaminated, you could possibly clean with IPA but the issues are likely to be beyond cleaning if it was powered up whilst wet/sticky.
Old 29th August 2019, 08:31 PM
peltool peltool is offline
Last year I had problems with my car (-05) console buttons. Car, CD/TV etc. buttons doesn't work at all. I bought replacement circuit board from ebay and now everything work well. No component protection etc. problems. Just plug & play. It cost about 90 £ delivered to Finland.
Last edited by Architex_mA8tey; 30th August 2019 at 10:43 AM. Reason: Edited to eclude name of supplier / breaker as forum is sponsored by one
