Old 19th January 2011, 05:36 PM
MOST stands for something like Media Oriented System Transport. It's a fibre-loop that goes round the car components.
Thankfully, you don't have to splice any fibres, but you do need to take at least one of the connectors apart behind the CD changer. Seriously, if you are happy to just put all your CDs on the AMI as MP3 on a hard drive, or iPod then it's a bazillion times easier to fit.
The loom should come with all the instructions on which connectors to take apart and stuff.
Old 19th January 2011, 06:03 PM
A8L Chick's Avatar
A8L Chick A8L Chick is offline
Aah I see, thanks hun-thats easy peezy then hopefully.
I will let you know how I get on.
Would anyone be able to give me a step by step for the VCDS? I need to open a module or something dont I??? (this is the bit I have no idea on)
07 Silver D3 A/S8L Quattro S8 front end, Xenons, Bose, Bluetooth, Voice Control, Autodim mirrors, Heated folding mirrors, Double Glazed Windows, Electric Rear & Side Blinds, Black leather Comfort Seats with front memory seats & mirrors, Front & rear heated seats, Interior/Exterior light pack, TV.I.M, AMI, Parking sensors Front & Rear, Air suspension (soon to be lowered), Keyless entry & Start/Stop, 4 zone climate control, Power Boot Open/Close.
Old 19th January 2011, 07:30 PM
Mine was plug and play, no vagcom work... Connected the leccy, looped through the fiber and voila, the CD changer and AMI both work fine now...
PsYcHe is right though, if you dont have the pukka 'upgrade kit' which comes with the fiber Y connectors and wiring then its far, far easier to remove the Cd changer and put the AMI in its place..
It does rely on a later version of the MMI though, but you'll have that no doubt in yours I would think....
Old 19th January 2011, 09:08 PM
It needs to be something like 3360 or similar to support AMI.
And yes, you may need to turn on media player 1 or 2 in VCDS. it's the main module long coding if I remember rightly (module 07?).
Old 19th January 2011, 11:02 PM
A8L Chick's Avatar
Brilliant-thanks everyone. I should be fine
I have latest software so all fine there
Fingers crossed for tomorrow.
Old 20th January 2011, 10:17 AM
A8 Doc A8 Doc is offline
Yep dead easy as agreed. Unplug one plug in other. I have a spare power splitter if you need one.
Get stuck gimme a bell. If you remove the CD Changer keep it.
Old 20th January 2011, 08:40 PM
also if you swap the ami for the cd - you dont need to drop the glove box. whole thing took me less than 10 minutes
