Old 28th May 2011, 04:05 PM
You could put them on as long as all are the same size but not recommended, normal size for 18" is 245/45R18. 225/40/R18 would be 6% smaller this would result in higher speedo reading, better acceleration, worse fuel economy and lower car plus I do not think they would look any good. For winter wheels narrower are better but You should look for higher not lower profile tyres. 225/50R18 would be good choice, maybe even 225/55R18 for increased ground clearance in winter but that would give lower speedo reading.
Old 28th May 2011, 04:15 PM
surveysteve surveysteve is offline
Cheers guys, I would be fitting new tyres to them anyway to run in winter.
So was just looking to see if I could run with the 225's.
I see Camskill do a 60.
http://www.camskill.co.uk/products.p...d=m11b0s4703p0
Old 28th May 2011, 04:19 PM
60 might be bit too much and speedo would read 7.3% slower
Old 28th May 2011, 04:21 PM
Yeah, I just checked that too. Does seem a tad on the large side. The arches may be in for some rubbing too with that.
Old 28th May 2011, 04:28 PM
225 x 50 x 18 will give you closest match to the 245 x 45 x 18
its only 0.7% too slow and very close rolling radius wise
Old 28th May 2011, 06:59 PM
Looks like I'm going to pass on the wheels I was looking at, they were going pretty cheap on a local VW forum.
I had a look for winter tyres to go with a matching rolling circumference and was not impressed with the lack of choice, with that goes a higher price.
Still, plenty of time before the snow arrives....................................
Old 28th May 2011, 07:13 PM
You could get 17" with 225/55/R17 for winter should be cheaper and easier to get but not sure if they will fit over S8 brakes maybe somebody else can comment on that.
reckon its due anytime soon round here
Old 29th May 2011, 12:16 PM
[quote=surveysteve;22436]Looks like I'm going to pass on the wheels I was looking at, they were going pretty cheap on a local VW forum.
Might want to have a look at these - my old winter wheels and almost new tyres http://forum.a8parts.co.uk/showthread.php?t=2812
