Old 6th June 2011, 10:43 PM
hmm, subtley different take on this. My bottom door trim appears to be one piece. Removal required the extraction of two bungs either end of the inside of the door. removal of two little screws revealed and slide the whole exterior trim away from the hinge end and then off. Clips secure to trim then clips (with trim attached) slide over corresponding little posts on door panel.
