  #31
Old 5th August 2011, 01:20 PM
Originally Posted by IceBlue8 View Post
Well. I never thought this would happen, but this is incorrect!
Both mats in the photo are upper mats. The lower ones have a lump of foam attached to the underside iirc. The holey eyelet fits flush with the button that protrudes from the floor, so you couldn't place another mat on top of it.
Anyway, anyone want a new front set of PF mats?
What I said was definitely correct, but I didnt look at your photos at the time and I confess, I cant work out what on earth you've got there.
The lower mats do have foam, yes, and the upper ones do not. The drivers side one is always smaller as it doesnt intrude into the pedal area.
Both mats, upper and lower should secure through 1 pair of lugs, with the lower mat sitting down low enough for the top one to click on top.
I'm quite sure the make up of pre and post face will be different, for the drivers side at least, as the post face for example had the kick down switch under the throttle pedal, which pre face does not. Passenger side may well fit.
In either case, getting a colour match will be hard. The only colours that were in both pre and post face was platinum, aka light grey, which is the colour you appear to have on the right of your photos ? And then still, the material will differ....
Just clean the old ones...
