Old 18th March 2009, 10:37 PM
Default Xenon levelling
My FL S8 sometimes generates the DIS message for 'headlight self level'.
It comes on even if the lights are off.
It's a PITA because it will 'self heal' and then fault again, causing the warning beep to go off and alarming the driver.
I appreciate that I could simply drop it off at Audi Glasgow, for fixing, but as they recently demonstrated that they cannot even check the gearbox oil level, I thought I'd try here first.
Old 23rd March 2009, 08:19 PM
There are 3 components to the xenon leveling:
1) The sensors, mounted on the front and rear suspension
2) The control module mounted at the bottom of the B pillar
3) The xenon headlights themselves
The sensors on the suspension are probably prone to the hardest life, so perhaps could be the first thing to check.....
Old 24th March 2009, 01:35 PM
Thanks Ian
I'll get the WD out.
Do you know where they are. Cant find 'em!
Old 2nd April 2009, 12:30 AM
Found the two transducers on the n/s suspension arms.
Took the plugs off both and dismounted and manipulated the forward one.
Made it worse initially (so it's prolly the front sensor.......dirty pot track maybe???)
Now it seems to be servicable.
What a great car!
Old 14th May 2009, 04:18 PM
It went u/s again and this time I fixed it for good with a s/h front level sensor, (£35 delivered from A8 parts). Thanks chaps!
Very easy to fit. Took about 15 mins.
