Go Back   A8 Parts Forum > A8 D2 > D2 - Common Faults
D2 - Common Faults Quick links to all known common faults and their solutions
Old 31st October 2011, 09:34 AM
From my experience having done the same fix to the manifolds on a car with them faulty, after the fix, the pull throught the midrange is stronger - You notice after fixing it, that in fact is had a flat spot around 3000 rpm iirc.
It is worth fixing, you *do* notice the increased performance....
Tags
facelift a8 d2 kickdown
