Old 10th November 2011, 12:45 PM
Basically this bit is the question:
Are there variations in the numbers of pins connected at the plug depending on how many twiddly bits there are in the mirror electrics that would make it easy enough to check if they're correct or not? Any obvious fittings for the auto dip function that aren't present on non-dipping mirror?
I basically need to know if it's possible to ID the correct mirror based on its physical appearance/wiring to confirm it is the part number I need.
If you could post a pic of the spare you have (especially if it's without mirror glass) and the wiring plug pins then that would help as I can compare to what I've been offered.
Mine's a facelift though, so may be different.....
Adrian
Old 10th November 2011, 01:33 PM
I think Facelift had potentially other options, such as auto-dim so it may not be very relevant.
Difficult to photo, but the glass is off so I'll describe the wiring as best I can:
Part label: 4D2 858 531 (+other number groups) 04.05.98
Captive socket that plugs in as unit is mounted: 7 pins of 10 (2,3,4,7,8,9,10) wires not accessible for further info.
Socket on fly lead: 7 pins of 10 - 3 of 4 outer large ones, 4 of 6 inner thin ones. No numbering visible, all 7 have wires on. I THINK this lead goes straight through the hinge mechanism to the mirror motors.
6 separate thin leads also appear through the hinge inside the unit, presumably from the "captive" socket:
2 black leads that appear to be for the heated mirror glass.
2 further black leads that loop back behind the glass to the outer side of what I think is probably the "folding" motor - can't see where they terminate.
Red & white leads that enter the inner side of the (presumed) folding motor.
Old 10th November 2011, 11:58 PM
Facelift mirrors are a different shape glass from prefacelift
Old 12th November 2011, 09:47 AM
i have a set of plastic ones that im looking at getting rid of in place of some chrome S8 ones mine are FL if your interested, do you still have your S8 ones ? can do a swap with cash your way if you like ? oh yes they are heated auto dimming and folding, just in case they differ at all
Old 12th November 2011, 01:06 PM
I'd like to take those Guy if they fit mine!! Can I get 1st refusal? I've been trying to get a pair of facelift mirror glasses for like 2 years from A8 parts lol
Old 13th November 2011, 11:52 AM
Cheers folks - great info
Guy - I'm not looking at disposing of the alloy mirrors. I want to keep them for the summer and run the plastic for the winter, or if I can't be bothered to change them back at least have them for when we move house to somewhere with a double garage with I don't have to worry about them getting stolen again!
I'm going to take a punt on the ones I've found being the right type - just need to agree a price that suits, in case they turn out not to be correct.
Old 15th November 2011, 05:08 PM
yes you can have first refusal, as soon as i can get hold of some ally ones you dont happen to have some do you ??
Old 15th November 2011, 05:30 PM
I did have but they were pf ones (doh!) and I sold them to RanjA8 lol
