View Poll Results: Cool or Not Cool
Cool 16 100.00%
Not Cool 0 0%
Voters: 16. You may not vote on this poll
Old 4th February 2012, 04:57 PM
It is a possibility briang9, might even have a mini meet at my place and use the rotary polisher.
that would be great, we are due to have another "Mini Jock Meet" in the spring which means the weather has a better chance of being fair I guess. we could certainly include a "master class" from you in the schedule I am sure.
cheers
Old 4th February 2012, 05:21 PM
47p2's Avatar
47p2 47p2 is offline
A little more of the Rover plus more beading porn
Old 4th February 2012, 05:24 PM
47p2's Avatar
The underside
Old 4th February 2012, 05:26 PM
47p2's Avatar
cheers
Not sure it could be called a master class but I'm sure I could give a few pointers in the right direction
Old 4th February 2012, 05:41 PM
47p2's Avatar
Thats the tidiest looking LSE I've seen in a very long time.... Mine was that colour - Somewhere underneath its exterior finish...
I did enjoy the LSE but when I look back it was like driving a 1960s Land Rover and not a luxury vehicle. Ardennes Green was the colour
Now this is what you call rear legroom with an 8 stone Akita to keep your toes warm as you sit on the hard shoulder in your RR Classic waiting for the tow truck
Old 4th February 2012, 05:42 PM
47p2's Avatar
Originally Posted by Night Train View Post
47p2, yes it is a coupe, in my ownership for 30 yrs now, nicely modified under the bonnet, but looking quite sad & having to leave my stable soon
Shame you are having to part with it, what mods does it have?
Old 5th February 2012, 07:46 PM
Night Train's Avatar
47p2
In partial answer to your question -
Mainly engine mods
4BBL Holley (manual choke) on Offenhauser 360 inlet manifold & heat insulator. matched manifolds
Full balance, lightened & nitride 10/10 R/G on crank
SD1 conrods (instead of the rubber P5B ones)
10.5:1 +020 pistons (forged)
Spike Anderson (of Samuri fame, for those that remember him - what a bloke!) Cylinder head rework in exhaust finish. - matched chambers adjusted to run on 4 star (premium unleaded really, being ali heads must have steel inserts).
Steel duplex vernier timing gears
Crane H200 Cam
Crane anti-pump lifters (will rev to 7k)
Lumenition
Stainless flexi fan (sounds great)
Baffled sump
biggest problem is that it destroys gearboxes (BW35 Jag 4.2 internals) & diffs (same as Range Rover (3.54:1) if showing up the local boy racers a bit too often..........
Other vehicles
Oh Yes....... The '98 PF S8!
Old 6th February 2012, 07:35 AM
[quote=47p2;32950]I did enjoy the LSE but when I look back it was like driving a 1960s Land Rover and not a luxury vehicle. Ardennes Green was the colour
QUOTE]
I could let you have my Land8 for the wk-end Sir and you could go back to thinking the Range is a luxury car again
Old 6th February 2012, 10:43 PM
47p2's Avatar
47p2
...biggest problem is that it destroys gearboxes (BW35 Jag 4.2 internals) & diffs (same as Range Rover (3.54:1) if showing up the local boy racers a bit too often..........
Funnily enough, as I was reading down the list I was thinking about the gearbox. Sounds like an awesome set-up
Old 6th February 2012, 10:47 PM
47p2's Avatar
What I meant by my comment was that it was a 1994 Range Rover which was more like a 1960 Land Rover when driving it. They really did have a lot of similarities. Best thing that happened was for BMW/Ford/Jaguar to take them over.
Weekend drifting in your Landy would be fine by me
