#31
ordered up the 3.7 ones and payed for them they will be with me tomorrow, just the control arms now, thanks for the info guys its been a massive help, hate spending money on the wrong parts, i confirmed that the 3.7 are the same across the bord with all 40v facelift models
will get the arms ordered now and get to work on them on monday morning thanks again for all the help my round at the next meet i think |
#32
lower front arms
Lower front arms aren't too bad....It's the tops where the pinch bolts seizes which is the real pain....just use plenty of wd40...
#33
I had No luck with WD40, Plus Gas, burning torch or air hammer, nothing moved mine. I've ended up getting replacement hub carriers
2003 D3 A8 4.2 Atlas Grey - Factory: Adaptive lights with coming home function, 19" wheels, Solar Sunroof, Bose, Nav, TV, Paddle shift sports wheel, sports suspension, sports seats, rear seats with electric lumbar adjustment, heated seats and climate all round, ski hatch, int light pack, auto dip/fold mirrors, voice command, cordless phone, wooden gear knob, towbar, power boot lid After: LPG, AMI with HDD Pending: DVB-T Tuner & fixing niggles Last edited by Godders; 10th February 2012 at 05:32 AM. |
#34
Also the problem with WD40 and other penetrating oils is that it cannot penetrate deep in short amount of time and leaving for longer most of it runs off and rest evaporates. What I do is wrap it with rags or paper towels soaked in penetrating oil and leave it overnight to soak. Quote:
#35
WD40 is not a penetrating oil - it's Water Dispersant and the 40 denotes the number of trial brews 'til it worked OK.
I do the wrap in dispersant soaked rags and leave as long as possible - well I used to when I did my own stuff. After that it's heat - heat nearly always works but it needs real heat, not a silly wee Halfords Gas Burner thing
Men have feelings too. For example we feel hungry..... |
#36
I use one of the Mapp gas torches when heat is required, a powerful bit of kit that works very well
. Nite Blue 3.0L SE Quattro |
#37
I need the car for work so can't afford to have it in pieces on the drive for a period of time whilst I soak and coax them out. I'll get these replacements on, soak the bolts on the current carriers (for a long while) and try and get them out - then they'll be up for sale. Another problem is that they can't be knocked out straight on the D3 (not sure about the D2) as the steering knuckle obstructs it's path. Quote:
Previous owner had the top front arms replaced 18 months ago and I bet they didn't replace the pinch bolts (invoice doesn't indicate as such) or grease them as recommended by Audi. Judging on how tight they were (4 ft bar on the nut !) I suspect they overtighted the original bolts and pulled them slightly off 'straight' making them difficult to move.
2003 D3 A8 4.2 Atlas Grey - Factory: Adaptive lights with coming home function, 19" wheels, Solar Sunroof, Bose, Nav, TV, Paddle shift sports wheel, sports suspension, sports seats, rear seats with electric lumbar adjustment, heated seats and climate all round, ski hatch, int light pack, auto dip/fold mirrors, voice command, cordless phone, wooden gear knob, towbar, power boot lid After: LPG, AMI with HDD Pending: DVB-T Tuner & fixing niggles Last edited by Godders; 10th February 2012 at 08:09 AM. |
