Old 23rd October 2011, 01:34 PM
Originally Posted by frankow View Post
Fitted them last week
I wouldn't even know where to start doing that, I think I must still have the original (very yellow) 1998 bulbs!
It looks like I'd have to take off the HID ballasts for the dipped beams then the back of the headlight unit just to get at them.
I know it was quite a mission to do that a couple of years back just to replace a failed (filament) main-beam bulb.
Or is there a trick to it that I don't know....
I've tried LED sidelights in my local runaround (Focus) but they don't last long. Look good, but I'm told the heat from the nearby main beams makes them fail.
Reverted to standard bulbs on that just last week after trying something like 4 different designs, none of which lasted very long.
Old 24th October 2011, 06:33 PM
frankow's Avatar
frankow frankow is offline
Originally Posted by IceBlue8 View Post
Interesting. Mine are a bayonet fitting, but the ones fromUltraLeds only have 2 LEDs
I had the same ones, like a small PCB with an LED on each side, but one failed after only a few months of use.
The one in my last link are much brighter and whiter, with the LED's being radial the light is emitted much better, I'll go and take a pic in a minute.
Old 24th October 2011, 06:59 PM
frankow's Avatar
A few pics, not great quality as their from an iphone and the car is parked too close to a wall but I couldn't be bothered to move it tonight.
OH, A WORD OF WARNING - the bulbs are quite small and whilst trying to twist the bulb in it's connector into the housing it came out and fell into the front of the housing. I managed to remove the lamp fairly easily and unclip the fixings that hold the lens to the housing. I tilted the whole unit forward and managed to roll the bulb out, still not fun though!!
Old 24th October 2011, 07:03 PM
frankow's Avatar
I'm talking about side lights here, not looked at what is involved to replace a HID bulb but I wouldn't think it should be too bad?
Old 24th October 2011, 07:11 PM
Indeed, maybe my post wasn't clear or you misread it?
What I'm saying is that, unless there's a trick I've missed, even replacing the sidelight bulb is a total mission on my car.
Old 24th October 2011, 07:23 PM
frankow's Avatar
My mis-read!
They are a little fiddly on the Bixenons as the socket is so deep, not good for my sausage fingers!
Old 24th October 2011, 07:39 PM
Mine are just HID dipped, normal bulb main. PITA.
Old 27th March 2012, 05:46 PM
Zip's Avatar
Zip Zip is offline
Question
One of my ultra led (2 led ones) ones has just failed after little more than a year. Anyone found anything more reliable? Not happy with the poor lifespan...
zip
Old 27th March 2012, 07:26 PM
Mine were c**p too! Both failed within a year and the company completely ignored my emails. Now installed Ultra Power Bulbs (Art: BU434P) but they've only been in a couple of weeks or so.
Old 28th March 2012, 10:58 AM
Nollywood's Avatar
Frankow, I've got a similar set-up in my sides, so all white, matches the Bi-Xenons perfectly.
Have you done anything about your H7 flashers, to match the white look of the rest?
