Are they Bi-Xenons sealed? Some people say they are and some say they aren't.
Also if they are sealed and are opened up for cleaning could issues arise further down the like like condensations etc? I need to clean some on the chrome as there are some water marks in there which doesn't look great :s |
Touching the reflector part of the headlamp with even the softest of clothes will result in marking it.
. Nite Blue 3.0L SE Quattro |
It's just the area within the red line i need to clean - is that the reflector?
It is and will mark but shouldn't make much difference to the light beam pattern. Worth a try using a microfibre cloth. The chrome is sprayed on and very fragile and marks easily.
I think it happens to all of them, my Bi-Xenons are pretty bad on both sides.
PS. Aluminium coating is probably treated in some way to prevent premature oxidation, if you try to polish/clean it you will not just leave marks but remove protective coating and it will oxidise and go dull pretty soon I would think. PS 2 Did some search online, here is interesting info about reflector coatings http://www.molalla.com/members/leeper/refcoat.pdf
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 7th September 2012 at 01:39 PM. |
