Sadly the dealer is not open on a Sunday, so I got stuck with a visit to the infamous Halfords who then tried to sell me the wrong fluid which was red in colour. After trawling through all the various types of PAS and ATF on sale, I located the correct one for the A8 and for the privilege of buying there was relieved of £14.99 for a litre. I just did not want to drive back to Dorset with low PAS fluid, having discovered it this morning.
...so, did the fluid fix your problem?
Unsure at the moment Amar,
its been ok for a few days, but last time it was weeks between the incidents. I'll check the fluid levels again at the weekend, see if its dropped which I truly hope it has not.
Change the fluid and clean the filter, PDQ! Mine went completely and the replacement pump was very expensive - it'll make the oil seem like a free sample!
I cleaned the filter before adding the topup.
The old fluid is very dirty, I'll add it to my to do list. 1) replace front crankshaft oil seal 2) flush / renew PAS fluid 3) replace instrument cluster.
After 2 trouble free weeks and 200 miles, the creaking has returned. Checked fluid level, all ok.
One thing I have noticed, is that it creaks when turning the wheel even with the engine switched off and no fluid in circulation so I am back to thinking something with the suspension rather than PAS. I popped the bonnet and tried to locate where the sound is coming from, but its impossible on your own.
I think the problem is the upper control arms on one side. I cannot afford to go OEM when they get worse, so will most likely get a cheap set from the bay before looking for someone to fit or assist fitting them.
