D2 - Interior Seats, dashboards, plastics, ventilation everything inside the cabin |
Right got it started, removed the side trim at the passenger tunnel side and located the big orange bit! Removed that and no water came
Difficult to tell.
Take the orange drain out of the car and see if a trickle of water into the open pipe comes out of the "valve" end. Either way clean out the valve with warm soapy water and check it works OK. Then soften it in VERY HOT water before easing it back into place. Unless it's 100% OK before cleaning I'd do the other side too.
I would also suggest you do the drains either side of the transmission tunnel, they are the ones you need to attack with the air hose, or if you can get it on a ramp I think you can access them from underneath
good luck
Audi S8 2015, Daytona Grey |
(luckily mine are free flowing)
If it is the scuttle drains then you need to clean out the scuttle before attempting to clear the drains
. Nite Blue 3.0L SE Quattro |
