Old 22nd March 2013, 10:00 PM
Buttons on airbag come in two different options: one for radio controls only and another for radio, Bluetooth and voice control. You can usually change between these two options via soft coding of MFSW ECU. Of course, button pictograms stay the same.
You sure its soft coding? I was prettty sure it was the 3 buttons themselves that generated different signals on the MFSW bus depending on the buttons types, and then once the MFSW controller receives them it just sends the messages onwards on the Infotainment canbus, which has connection to both phone (if fitted) and radio/nav. The buttons come on a small PCB, which has some intelligence...., one board on each side of the airbag.
Was pretty certain Id simply changed the type of buttons over before now and done no coding to get extra function.....
I could be wrong though, been a long time since I did MFSW work...
