Old 24th June 2013, 03:35 PM
The boys at A8Parts will know mate as they charge systems up there. IT will know too, he loves Dezzy's 8
Old 24th June 2013, 05:00 PM
Its defo under the bonnet. The label will mention R134a and a value, around 820g+-20g iirc for D2. D3 is more like 620g - Do check, dont take me hazy recollection for it.
Dezzys is more like 5 kg....
Old 24th June 2013, 05:40 PM
Ian, do you remember what viscosity of PAG oil is used in D2? You refilled during annual meet, so you should know
Old 24th June 2013, 06:20 PM
Cheers folks - will have a proper look tomorrow. Thought there might be a generic web site for all models someone would have bookmarked
Fitted an aero style rear wiper on the A6 this evening using Touran parts - much better than the original which juddered over the screen no matter how clean/wet it was!
Old 24th June 2013, 11:48 PM
I can have a look on my autodata, bosch data and tolerance data programs if you give me enough spec detail etc on the actual model age and engine of the car Adrian
Old 25th June 2013, 05:59 AM
Hi Neil
It's a 2004/04 A6 quattro Sport Avant 3.0 petrol
Is that enough info or need engine code too?
Adrian
Old 26th June 2013, 10:36 AM
Well got it done this morning - sticker with weights of gas and oil was on the underside of the bonnet, up near the hinges, so took a bit of spotting!
Was worth doing - stickers says 550g +50 for gas and 22cc oil
The machine pulled out 250g of gas, so that was pretty low. Also pulled 13cc of oil
Now filled up with 575g of gas, 23cc oil and 10cc of UV additive in case it springs a leak!
