Old 24th July 2013, 08:15 AM
Dave McB Dave McB is offline
After i had my fuel pump done by the garage it would cough and splutter at around half a tank and the cut out, and it was the assembly not fitted properly, still scared to run her too low but i haven’t had it die on me since i spent a day in the boot swearing at how rubbish a design it is. So could well be the pump.
Empty a 20L jerry can in it and see if it runs.
I had mine do that before the fuel pump chucked it - apparently they need programmed properly. The pump will cut out if the ECU thinks the fuel tank is empty. It needs reset with a 1/4 tank of fuel in it
Old 24th July 2013, 08:22 AM
richyb66 richyb66 is offline
and also it was an Audi UK car, so potentially a press/management car.
I can't find it listed under Silent Witness but given that there are 2 A8s together I wonder if Audi loaned out cars for this?
http://www.imcdb.org/vehicle_5749-Au...p-4D-1999.html
