Old 5th February 2014, 10:47 AM
Conquistador's Avatar
Default Where is my diagnostic port?
Can someone confirm where my OBD2/diagnostic port is?
Is it behind the ashtray in the front or under the steering wheel?
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 5th February 2014, 10:49 AM
Should be under the steering wheel.
Old 5th February 2014, 11:57 AM
Under steering wheel.
It clips to the steering wheel's bottom trim, so if there is nothing you will have to undo two screws behind the Alu trim, one on each side of the wheel
Trim, just pull it, difficult to break it really.
Last two screws for this job on side behind the fuse box trim
There is more screws but don't needed for clipping obd port back in
Old 5th February 2014, 05:36 PM
its right down by your feet, if you feel around the lower dash trim you should find it.
Old 5th February 2014, 05:53 PM
Yeah, sorry, closer to your feet than to a steering wheel
just on the edge where the trim under steering wheel is.
Recently I was thinking about moving it somewhere less annoying as its only a harness clipped to the trim.
It can be so awkward when you have to plug the cable in from outside with closed door and window down (often during calibration or lowering suspension)
There is a little compartment on the bottom right from the steering wheel which you can open and close. I was thinking to fit it in there.
It can be so annoying when you have to plug in and out many times.
Old 5th February 2014, 06:14 PM
Been thinking the same thing, and now with the imminent realease of this perhaps more reason to move it and have it powered only when ignition is on, Thinking along the lines of Mimicsx2 so there is permanent diagnostics in the car, or just use my Android Torque adaptor instead.
