Old 15th February 2014, 06:34 PM
Nollywood's Avatar
Default Anyone With VCDS In The Heathrow Area?
Hey ladies and gents, Just wondered if there was anyone local to Heathrow or the Hayes / Uxbridge area with VCDS?
My 2005 D3 4.2 Quattro was in the shop, picked her up on Thursday evening. Looks like the boys there messed about with the MMI, as it was all in German. And after reverting back to English, I have some things missing from the Car menu in MMI.
1) ASS (Adaptive Sport Suspension) settings.
2) PDC (Parking Distance Control) settings.
3) Electric rear blind settings.
The items all work, just no means of changing any settings. Most important is the suspension, as I am due to have my wheels refurbished, but with no way of putting the system into Jacking Mode...
I need to enable the hidden menu, so I can restore the missing items, this is where VCDS comes in.
I'm in the Hayes area, but willing to travel to get my car plugged in. I'm more than happy to pay for time spent. Can anyone help?
Thanks in advance.
Old 15th February 2014, 06:47 PM
I've got VCDS-Lite, will that do the job? 8 miles NW of Uxbridge.
Old 15th February 2014, 06:55 PM
Nollywood's Avatar
I believe it will work. My laptop went bust, so I'm a bit stuck! Not sure if VCDS Lite needs to be a registered version though.
Sounds like you're pretty local to me.
Old 15th February 2014, 07:03 PM
Hi Nolly
Completely forgot to call you after Christmas, sorry mate (I completely understand the situation you were in while I was sorting S8 grilles and I hope you understand situation I was in)
Anyway
If Lite won't do the job and you don't mind driving to SE28 then you can pop in any time.
Old 15th February 2014, 07:08 PM
I'm by Gatwick and have a full version of 908 VCDS with a clone cable that seems to work fine for all jobs I've tried. Am around tomorrow cleaning up the A6 pre-sale if it helps?
YES! mine IS registered; updated from a purchased VAGCOM.
(As stated in the list published elsewhere on this Forum. http://forum.a8parts.co.uk/showthread.php?t=1005&page=6 )
PM me if you want to pop over (not early) tomorrow. I'll probably be in all day, clearing up smashed fences, got nearly 50 metres of them!
Old 16th February 2014, 12:28 PM
Sadly that was no good.
Nolly just left and my VCDS will only read the engine on his D3. A bit of googling and we think it's because I don't have the right lead.
I guess he'll be contacting you next Adrian.
He does have a strange selection of symptoms including a battery warning.
Old 16th February 2014, 12:37 PM
Well I'm home at the moment but due to pop out shortly to try and buy an S3 Sportback I don't want, but the Mrs does.....
Old 16th February 2014, 01:07 PM
Nolly was talking about next weekend, if you're about.
But he does seem to have an unusual number of oddities since his bodyshop trip.
Old 18th February 2014, 02:05 PM
peanutmnm's Avatar
peanutmnm peanutmnm is offline
Hi Nolly,
I've got a Ross-Tech HEX+CAN VCDS cable. Had it a while but it should be compatible with your D3 and is the full licensed version.
Can't pretend that I know how to use it properly but if you know what you need to do then you're welcome to use it.
I'm over in Acton so about 8 miles as the crow flies.
Cheers, Mike
