You may find this useful Scott
PDF download link http://www.google.co.uk/url?sa=t&rct...68911936,d.d2k
oooo that will do.
Thanks.
Thanks for the document M-A8.
Going by that my system is gassed up and working fine from that side of it. The pump spins, the fan kicks in when I do a output test but not when the system is running and there's the correct pressure or at least its in tolerances. I'm out of ideas. lol
Is the compressor clutch working?
I can tell by looking at it but going by VCDS and using the document M-A8 posted it is.
The message block 1 on VCDs all seems to be in the required range to suggest its all working. EDIT: Due to bad memory I can't remember if I paid any attention to group 2 with in VCDS. Rereading the document it seems like a good one to read.
[center] 06 3.0TDI Quattro: Options: Soft close Doors & Boot, Electric Blinds, Keyless Entry & Start, Bluetooth HandFree, Quad Zone Climate, APS+, 3 Spoke Sports Tiptronic Multi Function Steering Wheel, Heated Seats All Round, Black Leather Comfort Seats, AMI, Sunroof, Drivers & Passenger Electric Memory Seats, Auto Dimming Mirrors, Bi-Xenons AFS2, Dab, Digital TV, Reversing Camera, AV Inputs, Fridge, Solar Roof, TPMS, facelift rear lights, 3G, remote boot closure, Tow Bar. Last edited by ScottD3; 18th June 2014 at 07:40 AM. |
My custom label file works.....to a point.
![]() Going by group 002 the compressor is switched off. 3 = Compressor OFF by Pressure Switch : Basic settings not performed 12 = Compressor off by Requested from ECU Not sure what 12 is apart, apart from the above explanation. At least number 3 might be something I can do. I went to the basic setting and started. Learning started. ![]() Learning Ended. ![]() Made no difference.
[center] 06 3.0TDI Quattro: Options: Soft close Doors & Boot, Electric Blinds, Keyless Entry & Start, Bluetooth HandFree, Quad Zone Climate, APS+, 3 Spoke Sports Tiptronic Multi Function Steering Wheel, Heated Seats All Round, Black Leather Comfort Seats, AMI, Sunroof, Drivers & Passenger Electric Memory Seats, Auto Dimming Mirrors, Bi-Xenons AFS2, Dab, Digital TV, Reversing Camera, AV Inputs, Fridge, Solar Roof, TPMS, facelift rear lights, 3G, remote boot closure, Tow Bar. Last edited by ScottD3; 18th June 2014 at 05:35 PM. |
I got a number wrong.
I missed off number two in the custom label file. 2 is pressure switch. 3.0 is "Display 3 Compressor off (pressure in refrigerant circuit too low)" But then group 1, display 4 says this "Pressure in refrigerant circuit in bar Calculated by Climatronic Control Module J255 via duty cycle of signal from High Pressure Sensor G65 display = less than 2.6 bar or greater than 29 bar (even briefly) Pressure in refrigerant circuit too low (system empty) or too high High Pressure Sensor G65 malfunctioning display = 2.6 bar to 29 bar Pressure in refrigerant circuit in permissible range" So its not too low going by the pressure sensor switch. It says this "If a compressor switch-off condition exists for the compressor (ı display group 002) the A/C Compressor Regulator Valve N280 cannot be activated, nor during output Diagnostic Test Mode (DTM) ( Output Diagnostic Test Mode)." I'm not sure what it means by this in the document about the display zones. Zone 2, Last compressor shutoff criterion Explanatory notes Zone 3, Last but one compressor shutoff criterion Explanatory notes Zone 4, Third last compressor shutoff criterion Explanatory notes I kind of want to side with low pressure but its saying its not low pressure. So what is it or is it getting it from somewhere else?
[center] 06 3.0TDI Quattro: Options: Soft close Doors & Boot, Electric Blinds, Keyless Entry & Start, Bluetooth HandFree, Quad Zone Climate, APS+, 3 Spoke Sports Tiptronic Multi Function Steering Wheel, Heated Seats All Round, Black Leather Comfort Seats, AMI, Sunroof, Drivers & Passenger Electric Memory Seats, Auto Dimming Mirrors, Bi-Xenons AFS2, Dab, Digital TV, Reversing Camera, AV Inputs, Fridge, Solar Roof, TPMS, facelift rear lights, 3G, remote boot closure, Tow Bar. Last edited by ScottD3; 18th June 2014 at 05:36 PM. |
The pump is gone.
Anyone ever fitted a pump to a D3?
Never did it myself, but you may well need an evaporator/dryer too if the system has been compromised. My PF D3 went through 3 under warranty until they replaced that at the same time.
This...??
(see attached for '06 3.0 TDi)
2006 D3 S8 5.2 V10 Ceramic Brakes, Bang&Olufsen, DTV, DAB, Rear Camera, BT, TPMS, Soft Close, Auto Boot, AMI , 4 Zone AC, Home Link, All Electric Blinds, Fingerprint, Ski Hatch, Black Extended Leather, Heated Sport Seats, Alacantra, Carbon Trim inc Aluminium Pack 2. 2015 A3 S line 1.4 TFSI - for the missus to keep her away from my car. Standard S-line equipment, no extras. 2006 D3 A8 3.7 V8 - SOLD but not forgotten Last edited by M-A8; 21st June 2014 at 11:33 PM. |
