So this was a free repair because it's a recall item or similar? I have a 3.7 D3 running fine (touch wood!) but very occasionally as you go to start it, it clicks as if the battery is dead, but a cycle on/off of the ignition and all is well. I wonder if this is also a similar issue?
Presumably and Audi dealer would know if a coil pack had been changed? |
Audi D3 S8 - 2007 - V10. B&O, Phantom Black, black and silver interior, and still completely standard with everything working as it should ![]() ![]() Audi TT - 2015 - Ultra |
Not sure it will fix the occasional starting problem, mine does it once every 3 weeks or so as well. I did some googling and I believe its a software issue from what I found out. Mine seems to happen if the start button is pressed rather than the key in the dash. I did have a link saved, but cannot find it now.
