Old 1st September 2014, 05:59 PM
It should be linked to the seat memory controls on the drivers door Steve so is the seat memory function switched off at the moment? If it is then switch it back on and set it up against one of the numbers and it should be activated from your key or when you press the relevant number on the memory pad
