Old 10th October 2014, 08:09 PM
Think you've hit the nail on the head on both fronts - thermostat is probably the first order of business, assuming the cluster is reporting the temperature accurately (measuring values should tell you)
When was the cambelt last done as it's usually changed at the same time - not sure on the V8s if it's accessible without removing the belt? Think by some good fortune it might be....
