D2 - Interior Seats, dashboards, plastics, ventilation everything inside the cabin |
I tell you what, I'd have had it back in a shot!!! That is a really good example.
Managed to get hold of a new control unit for £17 so I'll give that a try. Spoke to my guy at the dealer today and a new one is £1700 apparently!!! Hopefully it'll sort the issue, I can't handle the lack of heat. |
We'll the new module didn't make any difference but it was worth a try. Not sure what to try now really. Just noticed today that there is no heat coming from the passenger footwell either. I do have VCDS which doesn't pick up any faults. Any more ideas?
Well today I flushed the coolant system to no avail after a few people suggested there could be a blockage.
What I have noticed is that if I switch the engine off and back on, warm air will come through to the passenger side but turns to cold air 10secs later. Also got a new fault code today - 01274. Cleared it, fiddled with the climate control for a few mins and it never came back. I'm at a loss. Any ideas? |
01274 - Air Flow Flap Positioning Motor (V71): Faulty
Possible Causes Wiring/Connectors from/to Air Flow Flap Positioning Motor (V71) faulty Positioning Air Flow Flap Positioning Motor (V71) blocked Positioning Air Flow Flap Positioning Motor (V71) faulty Possible Solutions Check Air Flow Flap Positioning Motor (V71) - See Measuring Value Blocks (MVB) - Perform Output Test - Perform Basic Setting Check/Repair Wiring and Connectors
Yeah, saw that on Ross-tech site. Had a check and the 2 flaps appear to be fine. Plus that code hasn't reappeared after a fair bit of fiddling.
So, I'm totally at a loss.
Stripped all of the panels from the tunnel to gain access to the flap servos and all appear to moving and directing air as they should. I just can't work out how the temperature is controlled though??? Also plugged in VCDS and looked at some of the measuring blocks. Found that the left vent temp sensor was reading silly temps of around 35 degrees whereas the driver side was the standard 12 degrees. Decided to switch the sensors over which made no difference, the passenger side was still reading very high. Not sure if this is anything to do with the symptoms of no temperature control (always warm air to the drivers footwell and cold air to the passengers). Also just found that hot air will come through to the passenger side if I use the rest function????? So confused! I really don't want to take it to a garage, I hate being beaten. |
Sounds like the sensor for the passenger side is shot.. If it thinks it's too hot, it'll always send cold air to that side and warm to the other to keep the balance..
What happens each side if you set the temperatures to Max or Min which would override the sensors?
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 4th November 2014 at 11:12 AM. |
If switching sensors did not have any effect, then sensors themselves are OK, fault must be in the wiring or climate control unit. If it reads 35 C already it makes sense that it thinks it is already too hot so it's blowing cool air instead of hot but if you switch to max temperature it should be providing warm air.
It would also be interesting to see what temperatures the system reports (and how it behaves) with the sensors disconnected, each side in turn.
