Old 4th June 2015, 10:35 AM
That diagram is it. A single wire that runs from the instrument cluster through both the front brake pads and back to an earth.
Any wiring fault, nick, loose connection, rubbing, fault pad etc anywhere in the circuit, and the light comes on.
Its common to hardwire it to ground behind the instrument cluster to stop it false reporting if you have an issue other than worn pads...
