Have you tried sending MAP files to RossTech? Apologies if you already know about that.
http://wiki.ross-tech.com/wiki/index...ol_Module_Maps |
I don't think there is enough d3 demand for them to invest the time these days. If I had vas 5054 then I could probably get the info from that and write my own label files.
Del ![]() |
Was that with the gearbox in "S"? What brand and grade of fuel?
Rob -- 2013 Audi A7 BiTDi, with Tech Pack High. 2007 Audi S8, with Rear Seat Entertainment, Quad Zone Climate, DAB/DVB and electric blinds. ** sold ** |
Here you go Matt
Del ![]() |
![]() Quickly made a simple line graph. It's a bit jaggy as VCDS logs the speed with whole numbers. First observation looks like gear changes at 2 and 5 seconds. ![]()
Nice I did notice duplicate speed data in the column, that would explain the stepped nature to the graph, and yes your correct it does indeed go for another gear and shift into third just as it approaches 60.
Del ![]() |
Yes the runs were done in s mode, Fuel is Shell V Power
Del ![]() |
I've additionally calculated average G-force per gear for the first run.
1st - 0 to 28mph in 1.97s = 0.65g 2nd - 28 to 55.9mph in 3.23s = 0.39g 3rd - 55.9 to 62.1mph in 1s = 0.28g ![]()
Del ![]() Last edited by Delboy; 19th June 2015 at 11:26 AM. |
