Old 19th June 2015, 07:37 AM
I can't do it as VCDS has no label files for the s8 engine
Have you tried sending MAP files to RossTech? Apologies if you already know about that.
http://wiki.ross-tech.com/wiki/index...ol_Module_Maps
Old 19th June 2015, 08:09 AM
I have sent mine in a few times and even chatted by email with someone there, but it was a dead end.
I don't think there is enough d3 demand for them to invest the time these days.
If I had vas 5054 then I could probably get the info from that and write my own label files.
Old 19th June 2015, 08:35 AM
Witchfinder's Avatar
Witchfinder Witchfinder is offline
Was that with the gearbox in "S"? What brand and grade of fuel?
Rob
2013 Audi A7 BiTDi, with Tech Pack High.
2007 Audi S8, with Rear Seat Entertainment, Quad Zone Climate, DAB/DVB and electric blinds. ** sold **
Old 19th June 2015, 08:38 AM
I tried to import the data from the log but it puts empty rows between data and I can't think of a way to clean it up without doing it manually.
So I gave up
Can you repost the raw data and I'll take a look
Matt
Old 19th June 2015, 09:31 AM
Here you go Matt
Old 19th June 2015, 10:25 AM
Quickly made a simple line graph. It's a bit jaggy as VCDS logs the speed with whole numbers.
First observation looks like gear changes at 2 and 5 seconds.
Matt
Old 19th June 2015, 10:42 AM
Nice I did notice duplicate speed data in the column, that would explain the stepped nature to the graph, and yes your correct it does indeed go for another gear and shift into third just as it approaches 60.
Old 19th June 2015, 10:44 AM
Yes the runs were done in s mode, Fuel is Shell V Power
Old 19th June 2015, 10:57 AM
I've additionally calculated average G-force per gear for the first run.
1st - 0 to 28mph in 1.97s = 0.65g
2nd - 28 to 55.9mph in 3.23s = 0.39g
3rd - 55.9 to 62.1mph in 1s = 0.28g
Matt
Old 19th June 2015, 11:16 AM
You Sir are far too intelligent to be designing houses, should be designing stuff for cars instead
