Couple of thoughts on this , just in general ...
Does the auto box have a breather valve , is it clear The gearboxes that re occur and leak again could it be a fluid boil condition that creates gas build up pressure which escapes at the easy point .. ie gearbox out put seal . I also understand that it could be a design flaw . Years ago we had a old v6 Granada that when the owner towed his caravan up some big hill the box would leak from the torque converter seal , this was replaced but it leaked again whenever the caravan was on tow . We fitted an air fed gearbox oil cooler and it never leaked again after that , this was in the days when the only auto trans oil was the dextron |
The rear seal leaks diff oil rather than gearbox - only holds about 1 litre but makes a hell of a mess when it is leaking even fairly lightly. Don't think there's any breather on it?
Yes, as Adrian states, the final drive is total separate from the gearbox. It drips gear oil onto the cat and the burning smell/smoke is a good indicator.
So on the main gearbox where the prop comes out that has another section that holds ep oil ?
Is the 4.2 tdi d3 the same
Yep, that's basically it. Has a separate drain and fill on that part of the case
Yes can see it on a picture now , it has a prop that comes forward to drive front diff , I wonder if they suffer the same as land rovers where auto oil gets past the case seals and fills the diff part part with auto oil , it turns the ep oil pink and often spews out of the breather tube
