Old 21st August 2015, 08:57 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Interesting. How do you access this to check?
2007 Mini Cooper S R56
Old 21st August 2015, 09:17 PM
In the D2 you the mount is easily visible behind the rad on the right hand side of the engine.
Old 21st August 2015, 09:20 PM
Johnmed's Avatar
Wonder how difficult it is to access on the D3 and if/when we will see these failing.
Old 22nd August 2015, 06:47 AM
I had this fail twice on mine.
Old 22nd August 2015, 09:18 AM
I wonder how critical this front so-called torsional mount is anyway?
Most other cars only have 2 engine mounts and two transmission mounts and seem to do just fine.
By the way it had also failed on both my S8's
Old 22nd August 2015, 12:57 PM
I would have thought that the mount is critical in that the failures would appear to show that it is subject to (torsional?) forces which cause it to fail. That said i cannot say that i have noticed any significant change in engine vibration/movement when drving the car. But it has been up on jacks for the last week since a caliper seized and the calipers are away for refurbishment and so i havent driven it much since the mount was replaced!
