Thread Tools
Display Modes
#161
Not sure how you do it PF, is it not in the drivers manual?
On FL it's the DIS menu controlled via the button/knob in the cupholder tray near the handbrake (never did get that!), which obviously isn't there PF. If it's via VCDS, so be it, you only have to do it once after all and it's set. Where exactly is your receiver?
#162
>> I got in it Sunday night was display the time (+1 plus)
>> and also the and symbol... whaooo.... great.... This is great. Does it mean that on PF you don't have to fiddle with adaptation channel? I can't help with shifting the clock one hour though. On FL it is done via the same clock menu. You can only add/subtract hours in the radio controlled clock mode in the clock menu. You can't change minutes or date in this mode. Only hours. I'm sure the + and the - buttons on the cluster will do the same. Perhaps you need to long press them... I never tried though... You're probably the first one in the UK who has fitted it to the PF A8. You need to blaze the trail to understand how to shift it one hour. Good luck ![]() ![]()
I'd rather drive on left |
#163
There is no coding for radio controlled clock mentioned in ElsaWin and nothing about adjusting radio controlled clock in users manual I guess you have already tried the usual way of holding down both HR and MIN buttons pressed down at the same time for 2- 3 seconds like you do when normally adjusting clock?
#164
OK, put mine in today and placed the receiver in the same spot as HPsauce. But I can't seem to get the hang of the VCDS coding (first time I've tried doing anything other than a scan. Where do I find 'channel 19'?
#165
From here: http://www.vagcom.org/modifications/...trolled-clock/
(I think that's in instruments) VAGCOM / VCDS changes go to module 17, adaption 10, channel 19: xxxx0 = disabled radio controlled clock xxxx1 = enabled radio controlled clock so change the last number to 1.
#166
Thanks, got it. How long before I should expect to see the little radio mast icon?
#167
Tomorrow, if you're lucky. Should pick up summer time.
![]() You can fool it into checking earlier than the normal overnight process, but probably pointless, today of all days. ![]() (Someone worked out the logic, it's either earlier in this thread or linked to it. I fooled it just out of interest)
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 28th March 2015 at 02:56 PM. |
#168
Set the clock to 2.50am and then lock and leave the car for an hour or 2 - should have sorted itself out by then
![]() When it's set the date will be correct but the time will be on mainland Europe so you then try setting the time manually and can correct the hour, but no other settings. Be quick about it and come tomorrow morning it will have reset for daylight saving time automatically ![]() The little mast symbol will always display assuming there's no failed time sync in normal use - mine works in the factory position even though it's always garaged when it's checking the time
#169
Just to clarify, you set the hour offset (once it's got the radio symbol) using the menu control beside the handbrake.
#170
Jim, you can find some substance on page 8 of this thread:
http://forum.a8parts.co.uk/showthread.php?t=6843&page=8
