Old 25th February 2017, 10:41 AM
Simonbartlett Simonbartlett is offline
Hi Simon. It was very easy. No additional wiring, and quick coding.
Interesting there's a wheel the same as mine on eBay 😀 Airbag should be the same.
Owner of a 2008 A8 3.0tdi SE
Old 25th February 2017, 10:44 AM
If I buy the used wheel off eBay and it's scruffy ( hard to tell in pics ) is it possible to swap paddles over to my wheel ?
Old 25th February 2017, 11:05 AM
IF your wheel has paddles than its simple
This is on my previous car, but same thing and you need only follow first few steps.
http://forum.a8parts.co.uk/showthread.php?t=8854
Old 25th February 2017, 01:08 PM
Those new paddles look great, mine doesn't have paddles at the moment but wondered if I could use a sendhand wheel as a donor to fit paddles and wiring to mine.
Old 25th February 2017, 01:11 PM
This is the wheel I'm looking at on eBay, it's hard to tell but looks a little scuffed at the bottom when zooming in. Mine is mint but has no paddles.
Old 25th February 2017, 02:29 PM
If your one hasn't got the paddles then you can't retrofit it.
If its cheap enough I would buy it just for the chrome buttons as they cost few quid and are much better than PF.
Also if its cheap you could also get a tube of Woolies leather restorer and most of it if not all will disappear and wheel will look nice and fresh.
If you want these you will still need oem paddles as you only swap the actual paddle. This is how they look on black wheel with chrome buttons.
Old 28th February 2017, 03:52 PM
Turbo Tony's Avatar
Hopefully I've not misread a previous post, but can I swap my black paddles to the silver ones, even with a four-spoke heated steering wheel? I think the part numbers are different?
Storytellers Villa Orlando
2008 Audi S8
Old 28th February 2017, 04:19 PM
Yes you can.
Heating element plugs in to the steering wheels buttons same as paddles.
S5 and S8 aluminium paddles fit. There is one type of aluminium paddles which wont fit.
By the way, how comes your S8 have black paddles. Alu ones were only for S8's or at least on all of them??
Old 28th February 2017, 04:36 PM
New they are around £160 each so time for you to do some eBaying.
S/RS5 use the same part numbers for aluminium paddles.
If you lucky you can get them cheap second hand, few years back I bought a complete exc. airbag S5 wheel with paddles and chrome buttons for £90.
ID:	15790   Click image for larger version
Old 28th February 2017, 04:56 PM
Turbo Tony's Avatar
That's brilliant, thanks.
Yeah, I always found it strange, but I remember seeing another S8 with black paddles that also had a heated wheel, so I just assumed that having one meant I had to live with the other. They look wrong to me, so it's nice to know I can change them.
2008 Audi S8
