Old 9th April 2016, 06:00 PM
richardracer richardracer is offline
Default Security code not working in v15.7?
Hi there,
Loaded this up today and put in the quoted security code but it reports security error. Any suggestions from our experts?
Richardracer
2006 Audi S8 V10 Now Sold. Akoya Silver with black/grey leather, standard 20" wheels, hybrid TV, Bang & Olufssen audio, Heated seats front and rear, Dension ipod integration, DAB radio, keyless entry, rear electric blind, bluetooth connection to Apple iphone6S. Started at 60,000 miles end April 12. Now 171,500 miles as at Oct 2017. Now sold to fellow forum member.
Old 9th April 2016, 07:03 PM
Darius Darius is offline
Was just using this an hour ago or so, worked fine. What code are you putting in?
Old 1st December 2016, 03:30 PM
woodie227 woodie227 is offline
Thank you Delboy, you're a star;loaded the file as per your instructions of years ago(!) and it works a treat to test the accumulator etc. Never done anything with files like this previously so it's done my confidence the world of good too! Onwards and upwards eh!:
Newly purchased A8 Sport 3.0TDi (May 2008) D3 with ASB engine 71,000 miles. NO DPF!
Old 7th December 2016, 03:04 PM
kele kele is offline
Thanks for this. Very useful.
I also charged the Accumulator to 15.5 bar and stopped there. Supposedly this tells me the compressor is healthy but it did not sound too healthy I have to say. I keep looking for what's going on..
2022 Mercedes EQC 400
2008 A8 3.0 Tdi sport, B&O
Old 24th December 2016, 09:20 PM
Mine was putting out 7.8psi when I checked it vs 16 bar when healthy and that was after it had a "bagpiping andy" replacement seal kit applied to it, and it was causing the compressor to run for too long as it tried to top up the system. This in turned caused the orange light to come on when the compressor stopped due to over heating. Changing it for a new one has resolved all issues but the label file was helpful in being able to test the old compressor first etc.
Old 25th December 2016, 06:12 AM
Yes. I have drawn that conclusion too. I figure that with the miles on mine now and these codes, it is only a matter of time before it fails. Although on short, local trips it seems ok.
So i have a a new relay and compressor waiting to fit in the coming days..
Old 9th April 2019, 08:13 AM
Thanks for the label file Del, it works as you say.
I drained the whole thing down. It went much lower than it sinks to naturally through the leak, all 4 tyres hidden in the wheelarch. Then inflated the accumulator up to about 15 BAR (It took 8 runs to do this) and the compressor got to 97˚C so I allowed it to cool for a minute or two between runs. I wonder how many runs it should take? It seems to run for a prescribed amount of time each time. Last night I inflated the accumulator and the front axle to max and will check it in a bit so see what the pressures are.
I also will fit the new valve block this afternoon in any case as it is an early 08 part with 111,000 miles and mine is late 05 with 271,000miles. We are now pretty much at the stage where all used parts are >10 years old on the D3
Old 9th April 2019, 09:01 AM
Glad it worked well for you.
There is miniature ball valves on the pneumatic instrumentation market that could be cut and shut into the lines to assist with finding the source of leaks. Never needed it my self but it's the route I would take.
Old 9th April 2019, 02:53 PM
Just changed the valve solenoid block. £52 it was. Hardest part was jacking up and removing the wheel really. It is behind the front left wheelarch liner, the liner is in two parts, it is behind the rearmost half, sort of behind the repeater signal on the wing. 5 torx screws and it can be peeled back and access is easy without removing it.
It was not leaking around any connections, replaced and cleaned it all and tested again for leaks. Charged the system. Suspect no different but will need to drive and park up to level the vehicle properly. If no differen't hopefully can sell my old valve block as it must be OK.
Attachment 21276
Attachment 21277
Old 9th April 2019, 03:36 PM
Attachment 21276
Attachment 21277
This was the bits I referenced earlier so you can isolate a shock from the rest of the car thus finding the real problem.
https://forums.ross-tech.com/showthr...ll=1#post66453
