Old 17th November 2015, 11:31 AM
47p2's Avatar
47p2 47p2 is offline
Sump plug washer part# for 3.0TDI should be N0138504
It's a massive crush washer with outside diameter of 32.15mm inside diameter of 24.10mm
...and are fitting a new sump plug and washer when it gets here. So no real harm done.
So how are they going to do that without draining the oil, or will they drain it and put the same oil back into the engine
Nite Blue 3.0L SE Quattro
Old 17th November 2015, 05:23 PM
Johnmed's Avatar
Johnmed Johnmed is offline
I'm not following... Old plug and washer removed, new plug and washer fitted. Not much oil came out to be fair. Oil checked/topped up.
Just been under the car again now at home in the howling wind and dark. The sump plug is bone dry after a drive.
2007 Mini Cooper S R56
Old 17th November 2015, 09:11 PM
Surely all of the oil came out? That's how one drains it.
Old 17th November 2015, 09:32 PM
Johnmed's Avatar
The little fella just quickly swapped them over. If I'd tried it I'd have lost 8 litres!
Old 18th November 2015, 08:15 AM
That's how i did it when i found out for myself you can't reuse the washer (lesson learned) however i did drop the plug in to the oil catcher (i'd made) and ended up with warm oil running down my arm and dripping off my elbow, good times
Old 21st November 2015, 12:08 PM
Burnzybubbles's Avatar
Or just get yourself a peeler oil extractor and don't worry about a sump plug or getting mucky :P
That's how my 3.0tdi gets done and iirc how it's also done in Audi, I also suck all the oil from the filter housing so probably collect more oil than you would from emptying from the plug, people say you don't get all the crud from the bottom but unless you have lumps of crap bigger than 2mm in diameter then I'd say it's codswallop it sucks all the oil from the ferry bottom of the sump first, plus other less looked after cars i'v done i'v seen the crap in the bottom of the tank.
