Old 10th December 2015, 04:20 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Default Brake light warning came on after brief spirited driving
Hi all.
Did a U-turn very quickly and the traction control light flashed, then under acceleration the brake warning light flashed at me. Then went off. Hasn't come back on. I got home and thought I'd check the level of the fluid. The cap doesn't have a dipstick (nothing is simple). I wondered if VCDS would shed any light on the level or any fault codes.
In addition, some history:
Recently the N/S/R exterior keyless door lock button stopped working. No biggy. Contact cleaner didn't help. I mention this as there is a central convenience fault logged.
When I bought the car a year ago I scanned it on the test drive and the battery regulation fault that is present now, was then. So again, no biggy. The car starts fine.
When in the brake module I scanned for faults, there weren't any. I ran an output test (I know now I should t have). DIS went a bit nuts and a fault code 14 I think was logged. I read the procedure for clearing this on Rosstech's site, and tried to clear this, without luck.
So, to the scan:
Thursday,10,December,2015,16:24:52:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 4L0
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 18 19 1E 28 34 36 37
38 42 46 47 4F 52 53 55 56 61 62 67 72 76 77
VIN: WAUZZZ4E59N003044 Mileage: 189500km/117749miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Not registered 0001
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Cannot be reached 1100
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Part No SW: 4E0 910 402 G HW: 4E0 907 401 D
Component: 3.0L V6TDI G000AG 0030
Revision: --H05--- Serial number: AUX3Z0H5352725
Coding: 0011973
Shop #: WSC 02313 785 00200
VCID: 2045FE59F3D8C29
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 Q HW: 09L 927 156 A
Component: AG6 09L 3,0 TDI RdW 0020
Revision: --H01--- Serial number: 4462379
Coding: 0000001
VCID: 31630B1DA8327B1
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 J HW: 4E0 614 517 CP
Component: ESP 5.7 allrad H50 0540
Coding: 0008357
Shop #: WSC 02313 000 00000
VCID: 2A511C7185E4089
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 A
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0H5352725
Coding: 0412672
VCID: D8B516B96B08CA9
Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3670112
VCID: 244DF249E7C0DE9
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 P HW: 4E0 035 729
Component: Interfacebox H43 5140
Revision: 00000000 Serial number: 343FM087606601
Coding: 0000002
VCID: 2F670D65BE066D1
Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000151223
Coding: 0018449
VCID: 1C3DCAA9DFB0E69
1 Fault Found:
00065 - Left Rear Footwell Heater (Z42)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 6
Reset counter: 18
Mileage: 175130 km
Time Indication: 0
Date: 2015.05.27
Time: 13:00:41
Freeze Frame:
Voltage: 11.60 V
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 S HW: 4E0 907 279 S
Component: ILM Fahrer H16 0240
Coding: 0143121
VCID: 387536394B48AA9
Subsystem 1 - Part No: 4E2 910 113 C
Component: Wischer WWS D3 H60 0440
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H46 0390
Revision: 00046002 Serial number: AUZ5ZBH8466025
Shop #: WSC 00000 000 00000
VCID: 1A31CCB1D584989
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276W7200545
Coding: 0000001
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 E HW: 4E0 959 655 K
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CU000G2R4
Coding: 0431707
VCID: 2855E6799BE83A9
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 C
Component: J0527 0410
Revision: 00H05000 Serial number: 90055081590136
Coding: 0112141
VCID: 2649E84191FC2C9
Component: E0221 H02 0030
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 J HW: 4E0 920 951 J
Component: KOMBIINSTR. VDO H84 0620
Revision: D03 Serial number: AUDID3H5100027
Coding: 0000423
Shop #: WSC 10158 000 1048576
VCID: 2C5D1A698F10169
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 G
Component: Heizgeraet H08 0140
Revision: 0000000C Serial number: 00000009013887
Coding: 0000001
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B0861500DF
Coding: F5F99F7F507A0E00
VCID: 2D5B176DB40A1F1
2 Faults Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 243
Mileage: 189458 km
Time Indication: 0
Date: 2015.12.10
Time: 11:51:30
02077 - Media Player Position 2 (R119)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 167
Mileage: 173884 km
Time Indication: 0
Date: 2015.04.19
Time: 18:14:00
Address 1E: Media Player 2
Cannot be reached
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 C
Component: KLIMA-STG. FOND 017 0230
Revision: 00000020 Serial number: 00000000073194
Coding: 0000000
VCID: E1C33B5D38520B1
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 K HW: 4E0 907 553 H
Component: LUFTFDR.-CDC H07 4590
Coding: 0015510
VCID: 2B5F19758A1E111
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 3670122
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H52 1060
Revision: 00000000 Serial number: 364F%087797346
Shop #: WSC 00720 210 91789
VCID: 3B7F29357A7E811
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000815200094
Coding: 0035968
VCID: 1D3BC7ADC4AAEF1
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 F
Component: Türsteuer.FS BRM005 0180
Coding: 0028462
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 E HW: 4E0 907 289 E
Component: Komfortgeraet H10 0030
Revision: 00300010 Serial number: W040806190053
Coding: 0004317
Part No: 4E0 907 719
Component: Neigungssensor H05 0020
1 Fault Found:
00892 - Switch for Trunk Closing Cylinder (F248)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 1
Reset counter: 26
Mileage: 189400 km
Time Indication: 0
Date: 2015.12.09
Time: 14:35:39
Address 47: Sound System Labels: Redir Fail!
Part No SW: 4E0 910 224 B HW: 4E0 035 223 H
Component: Amp.-Basis H41 0150
Revision: 00000000 Serial number: 00000087525075
Coding: 0000013
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 D
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000026332
Coding: 0010101
VCID: 1E39C0A1C9ACF49
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 F
Component: Türsteuer.BF BRM005 0180
Coding: 0028462
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000221
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H02 0010
Coding: 0000006
VCID: 3F875D256E669D1
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 396F2087597823
Coding: 0000001
VCID: 2E591061B90C649
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000011259
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2806200063
Coding: 344530393135313035412056413032383036323030303633
2 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 3
Mileage: 175584 km
Time Indication: 0
Date: 2015.06.10
Time: 13:13:05
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Mileage: 1048575 km
Time Indication: 0
Date: 2015.06.10
Time: 13:18:34
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0028462
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H46 0630
Revision: 00000000 Serial number: 00000806170058
Shop #: WSC 12336 024 394758
VCID: 36693801415C5C9
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0028462
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08720814902398
Coding: 0201008
VCID: 234FF155E2CED91
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 C HW: 4F1 862 335
Component: BTA H11 0960
Revision: 00H11000 Serial number: 00000007580693
Coding: 0060001
End ---------------------------------------------------------------------
Can anyone shed any light on what may be the cause of the brake light, is there a way to manually check the fluid level?
Could a dicky battery be the cause of random faults?
Thanks for reading. John
2007 Mini Cooper S R56
Old 10th December 2015, 07:51 PM
Can you see the fluid level in the resvoir, the accelerating away quickly and it flashing on does sound a bit like fluid level thing .
With regards to the battery regulation , go into the battery regulation module and go into data blocks look for s.o.c .... state of charge ,with engine running see what the percentage is and post up .
Old 11th December 2015, 10:48 AM
Johnmed's Avatar
Thanks for that Lee.
Ok. Fluid was difficult to see, but topped up with Dot 4.
The battery SOC is 60.0% could that be because of the weather and because I was running VCDS last night?
Old 11th December 2015, 11:49 AM
If topping the fluid up fixes it bear in mind your brake pads could be getting low or could just be low on fluid for some other reason .
Take car for a good run 30 mins or so and see if state of charge gets any better
I had similar on mine , my auxillary heater kept knocking its self off in a morning , my car has had a new Bosch battery over orginal spec , but in the drop down list bosch batterys was not in there , i was getting the quiecent current stage 1 2 3 codes , so battery regulation stopped the aux heater from working .my S O C was 60 % or around that
See on the coding at the end the 105A im assuming that means 105 amp hour because thats what was on the orginal battery , so i changed that to 115A ....press do it /ok .
It changes the very long code slightly by 1 or 2 figures
The state of charge then went up to 90 % after a 10 min drive around it went up to 100 % , my aux heater as worked a treat since
Old 11th December 2015, 11:52 AM
Johnmed's Avatar
Very helpful and logical Lee.
Thanks.
Old 11th December 2015, 12:46 PM
Johnmed's Avatar
After 50 mins driving the SoC is still 60%. I wonder if this would explain why the D3 has been unable to jump start other vehicles...
Old 5th February 2016, 01:58 PM
Default Some comments about D3s and the Battery stuff ...
1. Easy to see why you thought this Lee but actually the 105 A is the last two parts of the part number. The original Audi battery just happened to have a part code that matched its 'Amp Hour' value.
VAG parts are xxx yyy zzz nn = vehicle subsystem part version
2. The Battery Meter % and its associated SOC values in the ECU that you read out with VCDS is one of the mysteries of life. The ECU calculates it and its value is shown in the MMI display but no-one knows what formula is used to determine it. I think Audi gave up on it, which is why it was removed at one of the MMI updates. After problems, I've seen the number 'stuck' at 10% on my car for three days before it magically returns to 100%, so don't trust it.
3. Best bet for working out the battery SOC is to use a volt meter across the battery. - 100% is 12.6V, 75& is 12.4V, 50% is 12.1V, 25% is 11.9V - all approximate values for 'normal' temperatures - Spring in the UK!
Old 5th February 2016, 02:00 PM
Johnmed's Avatar
Originally Posted by JulianHicks View Post
1. Easy to see why you thought this Lee but actually the 150 A is the last two parts of the part number. The original Audi battery just happened to have a part code that matched its 'Amp Hour' value.
Thanks for the clarification Julian.
