D2 - Fuel and Exhausts Everything to do with getting fuel into the engine, and fumes back out again |
Thread Tools
Display Modes
I've had a good 40 miles before I bottled it and filled up
![]() Though, I'm sure I read somewhere that the fuel pump is prone to overheating if you let it run too low.
The fuel pump issue is primarily for LPG fitted cars. If you run out of petrol and run on LPG then the fuel pump will burn out as it is running empty and therefore no cooling.
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. ![]() Last edited by Conan_the_Librarian; 24th August 2009 at 08:35 AM. |
I've had 90 litres into mine about three weeks ago. I went straight home and checked the handbook where it says the capacity is ABOUT 90 litres.
The replacement for the fuel pump that packed up a few day later, sourced from A8 Parts and fitted by Ben at AV Performance, is running fine. I don't have LPG. Makes you wonder |
Was just looking for a thread like this to see what the tank capacity is - had mine down to 20 miles range and almost on R
Managed to get 78.5 litres in without much effort but looks like I could've run it for a good bit longer ![]() Interesting to note Amar's old pic of fuel prices - paid £1.459 per litre for Shell' finest high octane go go juice today!
From experience, when the fuel guage reads empty on a car, uv usually got about 20 miles of fuel left.
I think its a safety/backup feature |
Don't forget the awkward shape of the 8's saddle tank, you'd never empty it.
1996 A8 4.2 QS. Bose, Solar roof, um...um... rally sport towbar. Now gone to a new home as the Traders 8. Bright yellow bus o love. |
I have run it to 0 miles range several times, and I either filled up to the top or plugged in VCDS, and its always had between 8l and 12l left in there. So thats at least another 30miles range, and potentially 50 on the motorway.
had mine the other day run out of fuel before the light even came on then could only fit in 78L.still something i am trying to correct, i assume the reading i am getting told is incorrect because wen i got the car i was able to fit 90l in it but it was a cold day in JHB aswel.
Audi A8 4.2 quattro 1995 |
I thought someone had siphoned some fuel from my tank when I'd parked in a space on a road that had a large degree of camber. I knew that the fuel range on the computer indicated 40-50 miles when I got out.
When I came to drive home, it claimed 0 miles. I chanced it and ran all the way home (20 miles from East India Dock to home). I even got half-way back again before my bottle went! I've also learnt something new from the forums as I've just re-read this thread - mine must have the 92L tank as it's an A8L FL 2000. I've only ever filled it up once and it cost £126. Yikes. |
Once managed to squeeze 80 litres into mine, but that was after driving about 30 miles on zero. Then again, my DIS is screwed up anyway and shows 1250 range on a full tank.
