Old 2nd February 2016, 08:56 AM
g-black g-black is offline
Default Strut air line connection
Quick question, is it possible to remove the little connection that stays on the airline once it's removed from the strut? And if so would it be possible to put it onto a new piece of airline?
What size is the airline? Been told 4mm and 3/16? Assume either would work?
Old 2nd February 2016, 10:38 AM
I haven't removed it on the car my self but instrumentation pneumatics must be similar and you may it easier to pull the nut back and trim the last few MM of the tubing
Old 2nd February 2016, 02:25 PM
From memory, it looks just like a standard schrader...
http://www.truckshop.com/product.php?productid=16663
Old 2nd February 2016, 02:50 PM
Are the struts push fit too?
Old 2nd February 2016, 04:19 PM
Not a standard schrader nor is it a PTC fitting.
Reason I'm asking is cause I'm waiting on new struts from Airrex, but in worried they won't be here in time. So I'm wanting to hook up my aftermarket air managment to the factory struts, so don't want to have to cut the factory airlines or fittings.
Old 5th February 2016, 03:27 PM
I knew I had air line parts in my 'parts bin' and got this out to photo for you.
If this is the connection you're referring to, then yes it can be reused assuming it's going on the same outside dia air line.
Name:	D3 Air Line.jpg
Matt
