Old 8th March 2016, 03:56 PM
Conquistador's Avatar
It will generally work as far as required for safety, but luxury goes out of the window.
Good point. That happened when I fitted a second hand HVAC unit a couple of months ago. The only functions available were rear defrost and the top button which blasts the front screen and demists. No heated seats or temp control etc.
When I phoned my local dealer (Audi Chelmsford) I got the impression, from two separate people, that they played dumb as to knowing what component protection is so then you are pressed to book in for "diagnostic" work and during that 60 quid half hour (probably more like 5 mins) they will just remove the CP.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 9th March 2016, 09:16 AM
TP_ TP_ is offline
Thank you.
Called the local stealership, they took 1000sek (equals 85´ish gbp) to do this.
Seems fair enough
Old 9th March 2016, 09:23 AM
Originally Posted by TP_ View Post
Thank you.
Seems fair enough
That's an ok price. There's an ecu per front seat so they'll have to remove CP twice, but they should only charge you once at 1000sek.
Matt
Old 10th March 2016, 11:59 AM
mcs's Avatar
mcs mcs is offline
The front seats you have are the standard seats. They have basic functions but depending on your cars options, it may require more work.
Sport seats have the exact same movements as comfort seats, but without the option of massage and ventilation. That's it. Instead they have exceptional bolstering and are a bit lower in the car.
I've seen some standard seats without power seatbelt adjust and missing memory systems as well as manual headrests.
If the standard seats in your car have memory, power headrest and belt, then it should be ok and may not throw a CP.
Mike
04 A8 - 4.2 Sport
Retrofits:
OEM Bluetooth phone
Bluetooth Audio Streaming
Reverse Camera
OEM Aluminium Package
Old 18th October 2016, 11:38 AM
TP_ TP_ is offline
Still considering this, dare I do this?
Old 18th October 2016, 05:19 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Do it. Why not mate? Other than the size, weight and CP, it's a doddle (easy).
2007 Mini Cooper S R56
Old 19th October 2016, 08:47 PM
quattronutter quattronutter is offline
Swap seat ecus from old seats to new seats and should work(ecus located under each seat)
Old 19th October 2016, 09:02 PM
Don't the seat ECUs talk to the car that they were originally put into?
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 19th October 2016, 09:33 PM
Original ecus swapped to new seats works fine
Old 20th October 2016, 12:46 PM
TP_ TP_ is offline
Ok, with ECU´s changed, will the new seats have all their functions, or just the basic one´s that´s with my stock seats?
