Old 13th April 2016, 09:55 AM
Default D2 and D3 - Heated Screen Washer Jets
Does anyone know for sure in each case (both D2 and D3) if heated washer nozzles are standard on all models and if they are fitted then what is it that triggers the heating? are they on all the time below a certain temperature or are they triggered only when either heated mirrors or rear screen is activated for example?
Many thanks
Old 13th April 2016, 10:04 AM
Standard kit from launch in 1995 by the looks of my brochures
I thought they were on all the time like mirrors, but would need to read a handbook to be sure
Old 13th April 2016, 10:21 AM
Can anyone confirm on all the time for both D2 and D3?
Old 13th April 2016, 10:33 AM
According to wiring diagrams, the D2 1995 is definitely on all the time...
Just checking D3...
Old 13th April 2016, 10:38 AM
Same on D3.
In both cases they are directly wired (via fuses obviously) from the switched ignition feed
Old 13th April 2016, 10:40 AM
and yes, in case you were wondering, exactly the same on the D4 too
