Go Back   A8 Parts Forum > A8 D4 > D4 - Transmission
D4 - Transmission Gearboxes, diffs, drive shafts.
Old 21st May 2016, 05:37 PM
Joe2.0E Joe2.0E is offline
Pretty certain it is G052145S2 as per the D3. It's available in 1 Litre bottles.
There is sure to be a ZF equivalent but as you'll need so little, it's probably as well to stick with the Audi Dealer product.
Old 24th May 2016, 05:24 AM
nath nath is offline
checked with the dealer yesterday and yes it is this part number
its about 25 quid a litre
luckily i have some motul stuff which is exactly the same grade
and il just to up this time and drain it completely when i know everything is back on song
Old 24th May 2016, 12:15 PM
When you eventually get to drain the old fluid, you might let us know what condition it was in ? Mine has never been changed and my old D3 had it changed once at about 200K miles. This was only done as a leaking output shaft seal was being replaced. It might be prudent to have it changed at a sensible interval rather than the "sealed for Life" response that most main dealers use.
Old 27th May 2016, 11:55 PM
ok got a little further tonight
managed to get the old sensor out (black one ) and replace with a new one
a miniscule drop of oil came out whilst changing over
the old fault codes have now cleared
but now i have a new one again relating to the problem
im struggling to find out how exactly how you code these in to the car
Old 28th May 2016, 09:20 AM
The elsawin attachment on the previous page gives info on coding at the end, I think?
Old 29th May 2016, 05:33 AM
it does mate and i have read it
however the diagnostics it describes are for the factory guided function machines
im trying to use my own vcds lead
but as i have not had to code anything into a vehicle like this before
im a little unsure exactly how to do it
Old 29th May 2016, 09:59 AM
Worth an email to Ross-Tech who should be able to advise what adaption channel you need, or a post on their official forum?
Old 30th May 2016, 12:55 PM
think i have it sorted now guys
it does look as if the fault was the black sensor (i ordered mine from tps for about 90 quid inc vat )
the sensor isnt that difficult to replace but you do require a 27mm DEEP socket
you wont get it out otherwise
the faffing bit was the programming
luckilly i had help from a guy from denmark over on the vcds forums
uwe at ross-tech suggested i went into basic settings and did an adaptation which codes the sensors with standard information
you then have to reset the codes and get rid of any fault codes
the only fault code that should then show is one referrng to the sensor not having been tested
go into the security section and enter the security password
the look for an option to "pressure test"
once this is done everything should be fine
thanks again to all those that helped sort the problem
Old 30th May 2016, 09:09 PM
Glad it's sorted, and thanks for sharing
Old 31st May 2016, 04:24 PM
may not be quite so straight forward gents
warning light is now back on again
about to go scan car again , but weather is doing its usual
