Old 16th August 2016, 09:24 PM
peiiider peiiider is offline
Default Strange cruise control issue
So since I bought my '06 3,0tdi a couple of weeks ago, I've noticed the cruise control is sometimes misbehaving...
Say I'm going along at 100kph, when the terrain varies slightly, sometimes the speed starts dropping. Slowly, slowly, down to maybe 90 or even 80kph. Then suddenly it seems the car discovers the speed is wrong, shifts down two gears and floors the throttle to get back to speed.
Other times the car keeps the set speed just fine within 3-4kph, no matter what hills or corners it encounters.
Only fault codes present are broken solenoids of both transmission mounts..
Any ideas ?
06 A8 3,0TDIq My daily driver and project...
97 A4 1,8Tq. Powered by a 4,2 from the '01 S6, full rollcage, FIA seats and 6-point harnesses, B5 RS4 KW Competition race suspension, B6 S4 brakes, 18" Toyo RS1 slicks, carbon fiber roof. V8 trackday racer
14 VW Caddy 1,6TDI from my employer..
(X)00 A8 2,8q, (X)97 A4 1,8Tq, (X)92 S4 2,2Tq, (X)92 80 2,3E
Old 17th August 2016, 12:12 AM
Strange one that, was the road rough and did you have any traction control lights on?
Only thing I can think off is the body acceleration sensors are telling the car that it not appropriate to accelerate.
I notice mine won't speed up if cornering but once on the straight again it does
Old 17th August 2016, 05:05 PM
No lights that I have seen, and the roads I've driven when this has happened haven't been rough at all..
Old 17th August 2016, 06:54 PM
Since the deceleration is really slow, it's almost like the throttle locks up at say 10%, when the change of the road means it needs 15% to keep the speed up.. From 100 down to 80-85kph could take like 10sec or something..
If I manually push the throttle then everything is fine and the speed increases, so I guess ESP/tc has no issues.
Is there any tb adaption that could be wrong like petrol engines have ?
Old 18th August 2016, 08:59 PM
Yes I'm with Del never heard of that one but some thoughts
If you press esp button to disable traction does it still do it
Are all the tyres of similar wear ...... thinking slight miss match on rolling circumferences on wheels .
Had a 5 series bmw few years back that would not always go into top gear and engage converter lock up and also would drop speed on cruise control and then pick back up ...... it happened when owner replaced rear tyres only
The fix was replacing front tyres aswell !
Old 19th August 2016, 09:50 PM
Problem is when I engage cruise control the ESP enables automatically
Drove around for about an hour tonight and didn't get the issue once.. Other days it happens more often, so it's not easy to figure out..
