D4 - Interior Electrics Airbags, Sensors, climate modules, instrument clusters, switches etc |
If you put the part number into ETKA it shows 4 variants
4H0953568B dropped in 2010 not replaced 4H0953568B Z00 dropped in 2011 replaced with 4H0953568H Z00 4H0953568B Z01 dropped in 2011 replaced with 4H0953568H Z01 4H0953568B Z02 dropped in 2011 replaced with 4H0953568H Z02 |
Excellent! That's the info Paul wanted
Thanks both, very helpful
Will keep you posted once I have bought one! |
So finally got around to this today - almost there but not quite 100% before it went dark!
I will write up when complete, but in short so far has been a new wheel, switch, slip ring and one additional wire When done I adapted the new slip ring and then used the output tests to turn on the wheel - started to warm up nicely but then a symphony of warning bongs and the dash lit up like a Christmas tree - almost every module reported an error in VCDS! After some troubleshooting I remembered my tendency to overlook the obvious, checked the fuse for the steering wheel module and it had popped - on checking it's a 5A fuse if you don't have a heated wheel and a 10A if you do - the heating element seems to draw about 7A Changed that, set about clearing fault codes in every module - all back to normal again. Slight issue, I re-coded the steering wheel module for a heated wheel, but I can't switch it on using the button. I can see from the measuring blocks the button works but when I press it I get the message "Heated Steering Wheel Turned Off" - it should toggle on then off. I suspect a minor coding issue - but it is dark so gave up - maybe tomorrow |
Any more joy today ?
For parts enquiries and Forum User Administration please contact customer services directly, not me - enquiry@a8parts.co.uk, www.a8parts.co.uk, or call 01642 783537 The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black , 2007 TT Roadster, 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
Sorry, slow to update with the hectic run up to Christmas..... but now say with my feet up - heated wheel all working perfectly. Will write up properly soon
Write up
Parts used:
4H0 419 091 AF – Heated wheel, 3 spoke 4H0953568B – Slip ring 4H0953551A - Button 8K0 973 754 – Plug (Slip ring connection) 000 979 009 EA – Repair wire Optional but well worthwhile: 8V0951523XHA – RS7 Paddles What I did: Remove the battery with the ignition turned on – supposed to minimise risk of accidental airbag activation. Remove airbag – with a screwdriver release two “catches” at 3 and 9 on the rear of the steering wheel (will be obvious when you look at your replacement wheel. Disconnect the wiring. Centre the wheel to help with re-alignment - Remove the large bolt that holds the wheel in place and pull the old wheel off the spline. Remove the upper and lower cowls (three screws for the lower). Remove the small torx screw that holds the slip ring in place, disconnect the wiring and unclip the steering ring. You need an additional wire from the steering control button to the slip ring, use the repair wire which connects into the existing plug at the button and into the new plug for the slip ring (where it will be the only connection). I wrapped this in cloth tape and routed along the existing loom. Install the new slip ring, re-connect the wiring. Change the steering control switch, two screws. Re-attach the cowlings. Optional – replace the paddles on the wheel, remove the plastic facia (just pulls off) to access one torx screw per paddle, the wiring is tight so be careful but they just swap right over. Install the wheel ensuring correct alignment (i.e. straight if that is where you started). Connect the heating wiring to the slip ring, re-install the airbag (wiring first then just push into place). Re-connect the battery. Change fuse 8 in carrier B (brown) in the driver’s side dash panel from a 5A to a 10A. Turn on the ignition, expect some warning lights! Plug in VCDS and check for error codes, you will need to re-calibrate the Steering Angle Sensor and possibly the Dynamic Steering if installed. Ross-tech have guides to do this. Re-code modules 08 and 16 to tick the “Heated Wheel” option. Change the default temperature of the wheel, go to module 16 (steering wheel), adaptation and select channel 10 – default is 28 (degrees C), I upped mine to 36! Check everything works, wait for a cold day and bask in the warmth from the heated wheel Photo of the finished article – when I did this originally I kept the original paddles, but I think the RS7 ones make a massive difference to the look and feel and help me remember the change for the 10 months a year I don’t want warm hands! |
Great write up Paul.
2010 A8 SE Executive 4.2 FSI D4 2007 Mini Cooper S R56 2008 D3, gone, but not forgotten after 9 years and 90k. |
Great write up I may well do this myself soon.. one of the few options my car doesn't have, and I really like the chrome paddles too. I actually use my paddles quite often as the car seems to over rev naturally and drop out of the power band (4.2tdi) I think the perfect change to maintain torque is around 3400rpm after that is a pointless wast of rpm.
Just working on this retrofit now to discover that maybe not all Audi A8 D4 steering wheel column looms are the same. The main harness connector to the Steering column control module I have doesn't have pins 1 (GND) & 2 (12V) wired.
A question to those who have done this, was this also the case for your install? Was pin 1&2 wired already or did you just replace fuse in fuse carrier 2, Fuse 8C to a higher rating? It looks like the steering wheel heating element can pull power from other pins (3 for 12V & 10 for GND) but it seems like the pins its meant to pull from (1&2) are a heavier duty so not to over load 3&10. Also the steering column switch - does that single signal wire go to pin 1 on that unused connector on the steering column control module? |
