D3 - Everything Else Anything that doesnt fit elsewhere |
Thread Tools
Display Modes
Alex. This issue can happen when clearing error codes too, it is advisable to go into the specific module in question and clear it manually.
Saying that, sometimes it isn’t necessary.
2010 A8 SE Executive 4.2 FSI D4 2007 Mini Cooper S R56 2008 D3, gone, but not forgotten after 9 years and 90k. |
I'm assuming then I need some values to enter to create a reminder at an appropriate point? I'll do some more googling. Cheers Alex |
I don’t have encyclopaedic knowledge of VCDS, but is there a channel called Instrument Cluster, which you can click into and have a play with?
Sure someone will be along soon to offer more help than I.
![]() Quote:
However, sometimes it doesn't seem to work! But if you run the VCDS SRI function, even if you don't change anything, VCDS stores the current values in the VCDS Debug folder. See an example from my 3.0 TDi attached. If you could look at yours and enter it here, we can probably help you ... Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver. Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years! |
